Thread Tools
Old 18-04-2012   #1
Another newbie with a Multipla
Hello all
I found the site having already stumbled onto the MultiplaOwnersClub site, and doing a Google search for M/pla ball joints. Anyone know a source for these as I don't want to buy complete wishbones and then have to discard their fitted bushes (which I intend to replace with Polyflex)... geddit
K20VTSW
Name:	Mutlipla 170412.png
K20VTSW is offline Reply With Quote Quote
Old 18-04-2012   #2
Re: Another newbie with a Multipla
Hi and Welcome
From memory with mine, (old shape bug) the lower balljoint is permanently fitted to the wishbone, so you won't be able to fit Polyurethane bushes to it. From experience, my ball joint failed before the two bushes did, and yet you can buy the bushes separately?!?
I think that the ball joint is riveted to the wishbone, you might get lucky and find somewhere that makes the balljoint to fit, that you then bolt on, but I couldn't say I've seen anything like this.
I hope this helps.
James
JamesAtthews is offline Reply With Quote Quote
Old 19-04-2012   #3
Thanks James
I shall persist in my search as I'm certain they must be available, whether rivetted, bolted or just pressed in.
They're not made as one piece with the w/bone.
And you're right to remark why the poly bushes are available separately, but there is a chance, I suppose, that the ball joints are fine and don't need replacing.
All the best
K20VTSW
Old 19-04-2012   #4
No strings on me
Eklipze3k's Avatar
Eklipze3k has donated!
Hi and welcome
As James said, the balljoint only comes as part of the arms so you will have to buy the complete unit. The bushes however can be removed and changed for uprated ones relatively easily, as long as you manage to get the standard ones out without too much fuss these can then be passed on to someone who might need them
Just FYI, not a lot of folk look in here for tech questions as it's mainly for introductions so any further questions should go in the Multipla section
Eklipze3k is offline Reply With Quote Quote
Old 20-04-2012   #5
Thanks Eklipze, understood.
Quote Originally Posted by Ektlipze3k View Post
Hi and welcome
Old 20-04-2012   #6
Trader Rating: 1
boilermansab has donated!
I don't think its worth the hassle..you can buy a complete wishbone for as little as 30 and its fairly easy to fit if all goes to plan!
boilermansab is offline Reply With Quote Quote
Old 20-04-2012   #7
semper in merda
widemouthfrog's Avatar
widemouthfrog has donated!
widemouthfrog is an honorary friend of the forum :)
+1
For about 64 (delivered) for a pair of wishbones with all bushes and balljoints, you could measure up, source your poly bushes and fit them, all with nice clean bits to work on and without taking your car off the road. Once that's sorted, switching them over onto the car should be a quick and easy job.
Famous last words....
widemouthfrog is offline Reply With Quote Quote
Thread Tools
newbie MULTIPLA 1.9 bellz love bug Newbie Central 1 22-06-2008 15:00
Multipla newbie Henrik Laugesen Newbie Central 2 21-05-2008 14:31
