Hi. First post and would like some help please.
I've been having the same problem as others, rear door wont lock, the key turns in lock but nothing. Have had a look and freed up the pin, rods all fine, can see how it all works etc, but turning the key does nothing! I can see what should turn (the plastic bit should turn 90 degrees ish, prev posts) to push the pin (that sticks, prev posts) but it doesn't. Tryed the 3mm allen key bolt loose and tight......so is it the barrel that's gone? 55 plate doblo jtd 1.9. Can't seem to see any other posts with this problem of the actual plastic pin pusher not turning..
Thanx for any help..love my doblo.
