mi tec electronics
"Technology Simply Sorted"
All vehicle manufacturers are covered including American. The process varies from each manufacturer. Some cars are corrected by simply connecting a diagnostic cable to the vehicles diagnostic port, while others need the instrument cluster removed to access the microchip. The time varies from 20 minutes to 3 hours on more complex vehicles.
All of our works are guaranteed and carried out to complete customer satisfaction and the standard we work to is far superior and unmatched by our competitors.
Sometimes mileage readings can be corrupted because of problems caused by electrical faults, flat batteries etc. Or for example, if you have purchased a new or second hand display to replace the car's original faulty one, the mileage reading will not be the correct reading for the car. Using the latest equipment and specially trained mobile technicians we can reset your mileage to any number that is require. Take a look at our other services too, including ECU Remapping & TV activation and mobile diagnostics and light resets
