Chimp001
I have a Qubo fitted with the standard Blaupunkt 2250 Mp3/B&Me Head Unit.
This has no pre-outs for sub/amps/line drivers etc and i'm not even sure how to find out what the output voltage is (All I know is it chucks out 4x30w)
Questions are:
1. Will I need to change the head unit to use the above mentioned power boosting items? and if so can this be done and keep original dash layout including console display?
2. Do I have to use a line driver to boost the output or can I just wire straight accross to the amps?
As you can tell i'm a total newb, with big idea's and some cash set aside for the job.
I already have 200w replacement speakers for the doors, rear shelf and 100w tweeters for the dash -all installed but on standard system.
I now wish to add in, 2X1000w 4ch amps (Sony).
First amp is for main/original speaker fitting, second is supposed to run off a second battery install in the boot connected to a custom made fibrglass roofspace install over rear seat; Qubo has loads of headroom.
Second install consists of 1x 8" Auna 600w sub and 2x 6.5" 200w Fusion encounters along with a 14" drop-down monitor with a DVD Player (this has power and monitor works but no sound connections yet).
Can anyone advise me on the kit i'll need to stitch it all together?
A wiring diagram would be really handy?
This whole thing is driving me mad, to have come this far and not be able to finish it :bang:
Questions are:
