HI ALL, i am new to this forum and would like to hello to every1 on here
i have a punto MK3 2003 53 reg, 1.2 petrol, 4 door, manual,
the problem is that the engine check light has come on?
i had a diagnostic check done, and it said i have a failed LAMBDA O2 sensor,
and also im only getting around 25/27 mpg!!! could the lambda sensor be the cause of using extra fuel? will changing the LAMBDA turn the engine check off?
and the other problem is the airbag light has come on!!!
can somone please please please help me,
thank you for your time reading this.
