heatherquilts
Having headlight problems with my R reg fiat Brava. I have sidelights and can flash my full beam but cannot get dipped headlights or constant main beam. When I put the stick forward to main beam is sometimes get a flicker of light. Have looked at other similar post and have checked the bulbs and the fuses also have removed the plastic casing around the steering wheel and wiggled the wires. Any other thoughts or is it a new stick problem and if how do you remove the indicator/light stick.
All thoughts greatly received as a daylight car at this time of year is hopeless.
Heather in Paisley
Heather in Paisley
