Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->How to Replace Key Microswitch<!-- google_ad_section_end -->
Multipla key microswitch replacement on a 2006 1.9 JTD Eliganza.
Published by Johnnyfrommars
05-03-2014
Difficulty Level: 1
User Rated:Unrated
Firstly you will need a fine point soldering iron, some fluxed solder, the correct microswitch and a steady hand/clamping holder.(The final pic shows the size of 'tip' required compared to a 1p!)
Separate the key fob by opening it via the slot at the top of the key fob near the metal part of the key.
Then you need to remove the PCB (printed circuit board) from the fob. It is just a press fit into the plastic case but be careful not to snap the pcb or damage any of the components on the reverse side.
You can see where the switch fits as there are 2 location holes that align the switch and the 4 contact points to the pcb where the solder needs to be. At this point I put a tiny spot of solder on each of the four contact points. (You could just solder on top of the switch if you like but I believe this gives a better contact)
Place the switch into the required position and hold in place with a small croc clip. Apply heat to each of the 4 contact points until solder melts. And hey presto one re-attached switch.
Just gently press the pcb back into position in the fob, close the fob (checking battery and outer 'button' position). If all this goes swimmingly then you will have one fully functioning remote key fob again! A saving of 175. Not a bad job!
If you don't have a soldering iron or the patience to do this I am willing to do it for you for 15 plus p&p (will have to look into how much p&p would be) There is a chap in Slovinia who offers this service on ebay at 20 + 7 p&p.
Old 06-03-2014   #1
Reluctant DIYer!!
Johnnyfrommars has donated!
Re: How to Replace Key Microswitch
Photos didn't attach as the preview showed? Lets try again! Also the switch required is a SWITCH-TACTILE-SMD-2-16N-Part-SKQLLCE012 (copy and paste this description to search ebay)
Thanks widemouthfrog thanked for this post
Don't Panic
Johnnyfrommars is offline Reply With Quote Quote
Old 07-03-2014   #2
Reluctant DIYer!!
Postage within the UK for this would be 7 signed for 1st class.
Don't Panic
Old 09-03-2014   #3
Reluctant DIYer!!
Don't Panic
Old 30-07-2014   #4
Warwick1973 has donated!
Hi, been to your email listing and sent you a mail via that with regards a miroswitch repair.
So that would be 22.00 inc P&P?
Can you mail me your address and prefered payment method.
Thanks, Warwick.
Warwick1973 is offline Reply With Quote Quote
Old 31-07-2014   #5
Reluctant DIYer!!
PM'd!
Don't Panic
Comment
Search this Guide:
(G) Which part of the electronic key can you replace? hmmmm Grande Punto 0 23-12-2012 22:26
(G) Remote key/microswitch wanted Andymultiprat Multipla 6 01-09-2011 16:30
(T) How much to replace master key? symonh2000 Coupe 7 15-08-2005 11:01
Replace/Repair damaged key cliveM Lets Talk FIAT 3 20-09-2004 01:45
Replace blue key cjras Lets Talk FIAT 6 18-09-2004 16:30
