![]() | #1 | ||
Posts: 4 Thanks: 0 Trader Rating: 0 ![]() | ![]() Hi. I am a newbie, this my first post😀 My daughter’s 2011 Punto Evo 1.4 had a power steering failure yesterday, after less than 2 miles from start up, first the dash dash warning and then power steering failure. Turned engine off and back on, the power steering was normal, but only lasted less than a mile before failing again. OBD 2 readier is showing code B10AA for Intermittent Proxy configuration control. Is this linked to the Steering failure? Is there any checks, hacks or fixes I can try at home? Marc
![]() | #2 |
Posts: 24 Thanks: 0 Trader Rating: 0 ![]() | Re: Punto Power Steering Problem Check the battery is ok and charging
__________________ https://badges.fuelly.com/images/sig-uk/1043335.png If you find a fix for your problem please let us know it will help others. |
![]() | #3 | ||
Posts: 26,647 Thanks: 1026 Trader Rating: 0 ![]() | Re: Punto Power Steering Problem What is the history with this car? Owned for years and trouble free.. Or a recent purchase that has sat for 2 weeks or more ?
![]() | #4 | ||
Posts: 4 Thanks: 0 Trader Rating: 0 ![]() | Re: Punto Power Steering Problem I bought as a first car for my daughter, who hasn’t been able to take test due to C19 restrictions. It has not had much use. I will check battery and charge rates in the morning. Many thanks
![]() | #5 | ||
![]() | #6 | ||
Posts: 26,647 Thanks: 1026 Trader Rating: 0 ![]() | The hundreds of sensors dotted around the car love a healthy supply of 12volts from the battery.. ![]() Seeing less than 9v can trigger errors.. quite often in pretty random patterns ![]() Yours isnt a 'conventional' PAS error And from what youve said.. lack of use.. therefore low state of system charge is likely ![]() Hence my question ![]()
![]() | Yvonne147 | Grande Punto | 16 | 10-08-2013 13:35 |
![]() | ste76 | Punto (Mk2/2b) | 1 | 04-06-2010 10:12 |
![]() | Ian Brown | Punto (Mk2/2b) | 1 | 20-04-2009 18:59 |
![]() | zadie | Punto (Mk2/2b) | 6 | 21-12-2007 13:19 |
