K koalar Distinguished member Written a review Joined Oct 24, 2016 Messages 8,860 Points 2,010 Location Cheshire Jul 18, 2020 #21 not easy once the engine is in Attachments ring.jpg 52.3 KB · Views: 68
portland_bill Patron member Joined Feb 22, 2004 Messages 9,879 Points 2,833 Location Faringdon, Oxfordshire UK Jul 18, 2020 #22 koalar Do you have a pic a bit further away, to show where on the engine that flat part is?
K koalar Distinguished member Written a review Joined Oct 24, 2016 Messages 8,860 Points 2,010 Location Cheshire Jul 18, 2020 #23 portland_bill said: koalar Do you have a pic a bit further away, to show where on the engine that flat part is? Click to expand... just had a look on mine now wet it looks to be bit lower than the one in the picture (diesel) looking at the front of the engine you have the exhaust manifold right under the left hand branch is quite a prominent block sticking out you can't get your head lower enough to read it. Might clean it up and check when the rain stops of cause if the barcode is still on the timing cover its also on there not as bad as I thought the number is on top of the block not the front this is the same as my 05 engine Attachments ring.jpg 124.8 KB · Views: 75 Last edited: Jul 18, 2020
D DaveMcT Distinguished member Written a guide Joined Sep 14, 2009 Messages 19,492 Points 3,294 Jul 18, 2020 #24 Clean the area with a scotchbrite or stainless scrunchy washing up thingy. They wont abrade the metal but will clean enough to read the numbers.
OP OP G Gardeneraceae New member Joined Aug 29, 2016 Messages 30 Points 11 Jul 18, 2020 #25 Thanks guys. That is really helpful And now I know there is an individual engine number I will have a good look for it.
J jrkitching Moderator Staff member Written a review Joined Mar 1, 2010 Messages 11,318 Points 2,906 Location Dorset Jul 18, 2020 #26 Gardeneraceae said: Thanks guys. That is really helpful And now I know there is an individual engine number I will have a good look for it. Click to expand... Note also that you will likely have to produce documentary evidence of the change before DVLA will update your V5C. From the gov.uk website: Attachments Capture.JPG 55 KB · Views: 30
