Old 10-06-2020   #1
France
Seicento/Cinquecento sporting, Swap T-Jet.
Hello, I present to you my Seicento Sporting and the Cinquecento Sporting of my friend Steve, the two will be swap with a 1.4 T-jet, turbo in low position thanks to a manifold ordered in Brazil, a Speeduino for Ecu, Punto Gt brakes, suspensions Ta-Technic to start.
The Cinquecento already had a 1.2 turbo, unfortunately it broke due to overheating, that's why we started with this one for the T-jet, we will do mine afterwards.
The old engine was a 75 with 1.2 16v 80 connecting rods and pistons, turbo gt1752 from Saab, reinforced cylinder head gasket, it run very well, in the 160 / 170hp I think.
I'm going to put some photos that I have.
Twenty95 is offline Reply With Quote Quote
Old 10-06-2020   #2
France
Re: Seicento/Cinquecento sporting, Swap T-Jet.
My Sei, my friend's Cinq, the first engine, 1.2 8v turbo and the DET3 ecumaster piggyback connected thanks to an interface between the harness and the original ecu.
ID:	209842   Click image for larger version
ID:	209844   Click image for larger version
Old 10-06-2020   #3
France
Cinq's exhaust, 54mm with Ducati's mufflers, Multipla's intercooler with oil cooler and Brazilian manifold for the T-jet.
ID:	209848   Click image for larger version
Old 10-06-2020   #4
France
Installed T-jet, engine harness modification and Speeduino wiring with stock ecu plug.
ID:	209852   Click image for larger version
Old 14-08-2020   #5
France
Old 25-08-2020   #6
Iíll be following this build dude 👍🏼
Rsoul is offline Reply With Quote Quote
Old 25-08-2020   #7
Ireland
What gearbox, clutch and flywheel did you use?
Build looks good!
shanere51 is offline Reply With Quote Quote
Old 02-09-2020   #8
France
Thanks guys,
We use punto sporting 6 speeds gearbox, with the 16v flywheel it seems to me and the clutch that goes with it, we will see if it supports the power otherwise we will mount a reinforced one.
The gearbox is a bit short for this engine but I can't find a longer one.
(Tu) Seicento t -jet swap info needed😁 ziziCRO Cinquecento / Seicento 18 18-08-2019 13:21
(T) cinquecento sporting shell swap lacinquecento123 Cinquecento / Seicento 17 26-05-2015 23:58
(G) should i swap my punto for a Cinquecento sporting buzz44 Cinquecento / Seicento 35 15-10-2009 21:12
