im Axle Specialists
Old 06-05-2020   #1
USA
Question Fiat 850 Spider 1972 Piston Rod torque?
Hello, I'm new on this forum, I'm looking for help, I need to replace the piston rings on my Fiat 850 1972 engine type 100GBC 903cc and can't find the Torque specification for the rod piston bearing conector, really need your help thanks!
SQB10 is offline Reply With Quote Quote
Old 07-05-2020   #2
Ireland
Re: Fiat 850 Spider 1972 Piston Rod torque?
Workshop manual looks to say 25.3 ft/lbs
Likes SQB10 liked this post
FR85 is offline Reply With Quote Quote
Old 07-05-2020   #3
USA
Really appreciate your help!! finally will finish this car , Thanks!
Old 07-05-2020   #4
Ireland
It's for the Berlina/Sedan but I would assume they are the same.
Perhaps hold off until someone else confirms.....
Gav
Old 10-05-2020   #5
Ireland
I think 25 lb-ft is correct for the 843cc models but the 903cc engine (similar to what is used in the 127) needs 29 lb-ft of torque applied to the con rod (what you call a piston rod) bearing cap.
Also the flywheel torque (just in case you've removed it) is 33-36 lb-ft on the 903cc engine (28 lb-ft on the 843cc engine).
I don't have an 850 'shop manual to hand, I obtained these figures from a car service data manual, maybe someone who has a manual could check?
Al.
F123C is offline Reply With Quote Quote
Old 31-05-2020   #6
USA
The Haynes shop manual confrms that 25.3 ft. lbs of torque is correct for the 903cc 100GBC series engine connecting rod bearing caps.
850 Dave is offline Reply With Quote Quote
(T) Piston connecting rod nut torque nm VitaPepe Punto (Mk1) 7 07-06-2017 20:33
(T) Wiring diagram 1972 Fiat 850 Sport a1969mach1man 500 (Classic) 0 25-05-2011 17:54
