I need help with removing the air bag from steering wheel? I have been trying to release it with the screwdriver in the hole in the back, but no luck??
Ok, I got it removed... The spring wire you have to push on is very hard to find, it is mostly concealed, it is near the top, and you need a tool with a sharp edge, otherwise you slip past it and cant find it. Yes a torx screwdriver would work. I used a 5mm round rod with a sharp square edge..
