Old 06-09-2018   #1
Replace or clean EGR valve?
700 quote to replace EGR valve on my punto. Should I clean it rather than replace? It's stuck open at the minute. Surely if I clean the EGR and throttle body, I've solved the problem for next to nothing?
Icklet is offline Reply With Quote Quote
Old 09-09-2018   #2
Dean
Zeewulf's Avatar
Zeewulf has donated!
Re: Replace or clean EGR valve?
Quote Originally Posted by Icklet View Post
Easiest thing to do would be to buy a second hand one from a scrappy, clean the hell out of it then swap it over with your current one. Then clean your current one out ready for the next swap over. That way it's just a bolt out/bolt in job and your ready to go again, giving you time to clean the replaced one again.
Zeewulf is offline Reply With Quote Quote
Old 09-09-2018   #3
Moderator
g8rpi's Avatar
g8rpi has donated!
Fit a restrictor / swirl plate while you are in there and you should not have to clean it again.
Robert G8RPI.
g8rpi is offline Reply With Quote Quote
Old 13-10-2018   #4
The EGR valve can be cleaned as new you have to use isopropyl alcohol 99.9%. This can be obtained from EBay and soak the valve for about half an hour then brush clean with a toothbrush. Do it in a plastic container with a air tight lid as the alcohol evaporates very fast. I did mine 2 years ago and it's still fine.
mbarrass is offline Reply With Quote Quote
Old 13-10-2018   #5
varesecrazy has donated!
Quote Originally Posted by mbarrass View Post
Thanks.
But pretty sure in the last 5 weeks they have done the job.. with good improvements
(T) remove and clean EGR valve camilozk Scudo 0 17-06-2016 19:27
(T) how to clean egr valve on ducato 2.2 multijet bigsparky Ducato 2 24-02-2012 22:45
(G) To Clean Or Not To Clean?? EGR Valve JimbbobW1977 Grande Punto 6 13-03-2009 18:26
(T) what does your egr valve look like and how easy is it to clean? yellowperil Stilo 8 24-03-2008 14:53
