Tipo (Classic) After many modifications and lots of TLC:
Before and after:
After:
In 2014:
A/C fitted Autumn 2016:
PAS just fitted, July 2017:
Key-less June 2017:
Front doors fitted with key-less entry.
Still completely rust free.
  • Like
Reactions: Michael Dranfield
oh!
that's interesting, about the pollen filter...
I recently bought a filter from eBay for the 146 (which seems to be an identical ventilation plant) as the picture showed it in a frame, which looked like it would fit the intake, above the fan.
However, when it appeared; it was just a large filter, like an air filter, about the size of a piece of A5
Interesting subject. I orderered a part shown on Eper for the Tipo. As you can see it is designed to hold a cartridge filter and appears to resemble the equivalent hole in the scuttle. However annoyingly the unit is too high to fit in the space available !
crikey!
'how deep does the rabbit hole go?!'
Those guys in Argentina fabricated that from galv steel. Looks like a piece of electrical trunking lid.
Ooh- you've really got the hooks in me now for a result.
Did you ever have the water cover for that intake SFB..?
Right-
Yeah: that looks about correct.
I think I'm going to try for a filter frame that drops inside the mouth of the intake.
I need a good morning with access to metalwork stuff at work, but with the car scuttle panel removed at the same time.
I've had some major clear outs in that area before- in Scotland; you don't want the leaves and damp collecting in that spot. I taped up the intake aperture whilst washing it all out.
The 146 & Tipo are identical in this respect...
Over complicated ? Maybe
Harder to seal off? Let's find out...
I always think; how would it have been done if it came out of the factory...
Admittedly: I've got a tendency to pursue over complicated solutions..!
