General 59 fiat 500 1.2 pop part identify
Team1994
Hi am new to this forum as had a problem with my 500 this part attached is spitting out water what is the potential problem and where can I find a replacement possibly a air con part but I'v no idea please explain
Looks like a coolant hose to me with a broken air bleed screw.
Do not drive car until this is fixed your car could overheat severely damaging engine,
I am serious.
You will need to have a new coolant hose fitted, the cooling system refilled with coolant and any trapped air bled out.
Where in the country are you ?
Someone nearby may help or suggest a good garage.
Thanks for the reply, not currently driving as off road but will get fixed as soon as possible, thanks again
I am serious.
I am serious.
Yep, exactly that. Quite a few threads on this, mine went and the new hose with the valve was around £30 from memory. Although I did make a successful repair and ended up not replacing the part.
Spike
This happened to me, I had to replace the whole hose.
If you're very good at DIY you can drill out the remaining bleed screw and remove it, then replace it with a "number plate screw + small [O] ring" or simply replace the whole pipe-dealer only part, note its hard to remove the clip near the bulkhead. as a last resort, place a small piece of rubber over the top and use a "G" clamp to seal the top.
Once "replaced" never turn the screw when hot.
Spike
Yep, and you kindly sent me your unused pipe allowing me to fix ours, many thanks, again.
