Technical Grande Punto 2008 fuel cut off switch location.
dee121
Hi
My 2008 Grande Punto 1.4 3 door hatchback won't start.
It turns over but will not fire up. I checked for spark and I have one.
It is as if I am not getting fuel through. I ran out of petrol and topped it up again but now it wont start.
Where is the fuel cut off switch on this model?
And would appreciate any ideas. Would a tow start it?
Thanks.
Hi
Thanks.
Hi, and welcome, :)
turn on the ignition , can you hear a buzzing from under the rear seat..??
that's the fuel pump.. if it's running - you have another issue,
I believe the reset button in on the plastic trim , UK passengers footwell,
near door hinges
here is a helpful thread - IF you are having more trouble - reply to it..
https://www.fiatforum.com/grande-punto/291663-fuel-cut-off-switch-help.html
do let us know what you find..,
Charlie - Oxfod
driver side (uk) drivers footwell in the plastic trim there is a hole... (look at the passenger side similar place to the bonnet release pull)
Later models have a reset via the indicator stalk
To reset car operation, follow this procedure:
turn the ignition key to MAR;
activate the right-hand indicator;
deactivate the right-hand indicator;
activate the left-hand indicator;
deactivate the left-hand indicator;
turn the ignition key to STOP
Hi
you wrote,
"turn on the ignition , can you hear a buzzing from under the rear seat..??
that's the fuel pump.. if it's running - you have another issue,"
can you explain what you mean, thanks.
Is there a way of checking if fuel is getting through up to the engine?
Andy Monty
Is the fuel cut off switch in the drivers side underneath a plastic trim on the side wall of the footwell near the door???
Could there be an air lock because I ran out of petrol???
Somebody help
I have grande punto 2009 1.3 multijet
The engine crank but wont start, and the central looking doesnt work.
I am so confused.there are not power suply on the fuel pump uder the rear seat (I checked on pump conector)
I cant find cut off buton to reset (maybe doesnt exist)
Maybe I have problem with immobiliser ?
Or some relay is stuck ?
Experiences please ?
Somebody help
Hi.
If immobilised.. the keycode:padlock symbol will come on.. but NOT go off.
Does it work like this.?
The central door locking may be unrelated.
Charlie
