Cinquecento Hensey's 1386 16v build
Some may or may not know my 1242 8v Schumacher seicento build thread here:
https://www.fiatforum.com/showthread.php?t=428240
But anyway I been lusting for a Cinq for a very long time and a good friend of mine decided it was time to get rid off his so I couldn't say no for the price
Spec at the min from what previous owner has told me is
P75 engine (inlet manifold is broken so if anyone has a spare lying around give me a pm)
P55 six speed gearbox
Comp m05s
Lowered 40mm
Pollybushed here and there have found the rear trailing arm and tbelt engine mount bushes in the boot
Pgt brakes all round with drilled and groved discs
Omp steering wheel and maybe an omp boss
Yellow Lockwood cluster faces
Full supersprint exhaust system including super sprint 4-2-1 manifold
Meant to have a 40mm tb haven't checked this yet
And maybe a few other bits and bobs I've missed or I haven't found yet
Currently the heads off the engine it come with every thing to refit but some how the inlet manifold has been broken so I need for find one or another head with one and needs the rear callipers re fitting the are brand new in a box in the boot i've looked all over and the only rot I can find is in the wheel arches
So the game plan is to get it running and driving so I can make sure the running gears okay then straight onto getting her looking nice
Now boost is loading I am in the process of buying parts as and when they come up forsale or Making it myself but so far I've got a manifold and decomp plate
Re: Hensey's 1242 8v turbo build
doh!
I do seem to remember it was a tiny bit rusty on the lip at the bottom (iirc there was some pressed holes and it was going around there in the inner lip).
Where did the engine / ECU / brakes end up?
Did the apron get repaired, as it was a bit charred from when I had it :D
(I'll stop derailing your thread now!)
doh!
Yeah that’s exactly where the boots gone rusty :(
And the engine/gearbox ect went into
https://www.fiatforum.com/showthread.php?t=429102
And tbh I just painted the apron block and fitted it to my sx I had at the
Time
So it’s been going Well Drive the Cinq after sorting the handbrake cable coolent pipes and a few other bits
Then the brake pipe decides to leak..
Then fixed that drove it to work and decided it wanted to break down and cut out haven’t got spark and it’s not injecting fuel thought cranksensor replaced that still the same so kinda stuck at the minute as what to do
So brooklands was a good day unfortunately didn’t actually take mine as it still doesn’t run but it’s old p75 made it there and back flawlessly without issue also Dad too my uno to see if it’d sell on the day
Also brought a new backbox in the way of a magnex stainless item should fit the abarth apron nicely just have to make the rest of the system out of 2” so should be 2” from the manifold back into some kind of sports cat then into this box that I believe is 1.75”
May I ask where you got the Magnex box from.
What size tyres are on the cinq? looks good.
Is this some kind of trickery? 5 Cento's parked on an incline? Seriously? Not one of them has the usual duff handbrake linkages? :eek:;)
