Technical Pinto speedometer not working
Madlandy
Hi can any one help i just got a 06 punto but the speeder is not working and the miles counter with the clock is flashing on the back any help please:slayer: and its not clocking up the miles any help please...
The Mileage and clock are flashing on and off together = Dash isn't Proxy Aligned (ie the dash isn't communicating / sync'd up / talking the same language to the car
It needs to be plugged into a a decent snap on code reader or to an auto sparky
It may explain why the speedo dont work
But it dont explain why it suddenly lost its sync either
it could also be hinding other issues - like a bust speed sensor
Are you a ABS or non Abs application?
What works happened recently to the car?
Ziggy
Hi is no abs and I just found out its had to have a other ecu from a other punto
