Another year has passed, and so did the 100.000km mark!
(Yes, I know, the Doblo can use some interior dusting and detailing :yuck: )
Maybe not in Fiats book, but in my book this means: oil change and check-up time!
Wheels & Tyres:
There was a little shake in the steering wheel at around 115km/h: the balance of the front wheels needed a little adjustment -> SOLVED
The Fulda tyres I have on my 17" alloys provide plenty of sideways grip and do a great job dispersing water according to my view in the mirrors.
I definitely recommend them as an affordable option on the REAR axle of a FWD car.
However the front pair is wearing down fast and is just as miserable at finding traction in the wet as the almost-worn Vredestein all-seasons tyres I had on the stock 16" steelies.
I do NOT recommend them on the front axle of any FWD car that puts down a bit of torque.
:idea: One of the Fuldas found a stray screw, had been plugged, and now resides on the front axle where it will wear down fast.
I will NOT rotate these wheels and replace the front tyres by something better when they're done for.
Timing Belt & Waterpump:
The coolant level hasn't dropped below minimum since we discovered the pump had an episode of incontinence.
The timing belt appears to be in great condition but moved ever so slightly to the engine.
:idea: No worries there, but a new kit will be put on at the 110.000km mark, which will be at a little over 4 years of life.
Electrical:
While checking the battery, the test instrument showed "Good condition, charge".
This was unexpected since I've driven quite a bit on the motorway (120km/h, 3400rpm) before going in for service.
While the engine was running we measured only 13.5V at the battery, which went down further when turning on the lights/blower/defrost.
The alternator delivers a nice 14.2-14.3V with an idling engine, but...
We discovered a burned spot on the shrink wrap on the starter-side terminal of the cable going from the alternator to the starter!
:bang:
Time to do something about it to avoid being left stranded or worse.
:idea: Instead of just replacing that cable, we'll do a bit of upgrading... SOON!
Brakes:
I've never been very happy about the performance of the brakes. Pads and rotors that wear equally fast is also a trend I'm not a fan of.
While the front wheels were being rebalanced I've taken a good look at the 3/4 worn pads and rusty rotors (both still factory original) and decided it isn't to much of a waste to finally put something else on there. :yuck:
:idea: A pair of known-brand coated rotors and a set of brakepads of a brand I've had great experience with in the past is ordered and will be installed... SOON!
