FIAT Auto Specialist Team
Old 29-07-2015   #1
Philippines
Hard to start in the morning or after 5hrs or more (1st cranking but wont start)
Hi there!
I've got a Fiat Uno Turbo I.e from my grand father, before he past away or maybe a years before he past away, he got a problem this this car.
It has a morning sickness (it is cranking but wont start, then after a few tries it will start but doesn't idle properly) it has low RPM until it warm maybe a minute after it starts. but it runs properly, a strong engine I have, but after few hrs, maybe 5 or more it is hard to start again. I already checked the distributor and it has a spark. and I already changed the fuel filter. but it has the same problem till now.
Kindly help me to repair this kind of car I've got.
Thanks a lot
allan26 is offline Reply With Quote Quote
Old 04-08-2015   #2
Philippines
Re: Hard to start in the morning or after 5hrs or more (1st cranking but wont start)
Is this forum active? I posted a thread 5 days ago asking for help.. then if this is active NON OF YOU USER's HERE DID NOT REPLY ON IT!!
Old 04-08-2015   #3
Fiat 500 Devotee
werdna's Avatar
werdna is part of the official FF Events Team :)
werdna has donated!
It might be better if you posted this in the Uno section...straight to uno owners !!
werdna is offline Reply With Quote Quote
Old 04-08-2015   #4
Moderator
g8rpi's Avatar
g8rpi has donated!
Quote Originally Posted by allan26 View Post
Hi there!
Thanks a lot
I don't know much about the Uno, but early injection systems had a cold start enrichment injector, this could be at fault. Alternatively the ECU may think the engine is warm due to a temperature sensor (or ECU / wiring) fault. Does the temperature gauge work properly?
Does your particular Uno have a diagnostics port (it will be a 3 pin)? if so you should get a copy of Multiecuscan (the free demo is OK to start) and a KKL/VagCom interface with ADAPTER CABLE 1 such as ebay item 251603446444 (try your local ebay with the same search). Look for faults and also to see what coolant temperature the ECU is reporting.
Please remember that this is a hobby group, not a free service, and if members have not seen your problem they may not reply. Also as much information as possible, for example exact model and engine type and size is useful. The same "model" sold in different countries may have a completely different specification or even engine.
HTH,
Robert G8RPI
g8rpi is offline Reply With Quote Quote
(T) Punto mk1 wont start this morning !! WoodyPuntoMK1 Punto (Mk1) 7 21-11-2011 16:23
(T) Problem in the morning’s 1st start sarbajit Palio 13 31-01-2011 08:16
(T) Wont Rev high on 1st start up thedjse Cinquecento / Seicento 4 12-11-2009 15:48
(T) Clock Resetting during start up / cranking caprimancars Punto (Mk2/2b) 8 30-12-2007 14:55
(T) wont start some morning!!!!!!!help 02fiat Punto (Mk2/2b) 2 22-02-2007 12:52
