Has the fuel shut off button popped up perhaps?
Usually at the kick plate to the right of the drivers (UK) side, there should be a hole just bigger than finger size.
You will feel a rubber covered button. Push it down till it clicks.
If not that, are you certain it is fuel related? Any stored fault codes?
