Technical Headlights not coming on!
Mro
Hello all
I'm sure this one is a quickie for you...not so much for me.
Headlight (1) not working so bulb from working side tried on the not working side.
Which meant both didn't work after that?!
Both bulb now replaced and fuses changed as well (internal fuse box) not one under bonnet.
Ps the full beams are working ok
Thanks all
Mro
Hiya Mro-welcome!(y)
Re-your bulb issue. The connectors can sometimes build up a bit of crap on them which can dull the connection, so usually a bit of fine sandpaper with clean them up, taking them back to the shiny metal. In other instances the wiring can work loose from the connectors thereby creating a poor connection to said bulb? As an idea too, test the wire connecting to the bulb to see if there is power going through it as well, maybe there's a broken connection within the wiring which you may not be able to see?
Guys on here might have some other ideas too ;)
