7 faults showing and won't clear,02 airbag control unit supply voltage,1a airbag indicator lamp,then 5 other faults ,all 01 airbag control unit,can anyone help thanks
Well the most importan one there is airbag supply voltage if there is no / isufficient voltage you'll have all sorts of errors, check the fuses then check supply wiring.
