Old 18-02-2013   #1
Ireland
Lightbulb Dash light warning light on - all lights appear working
SOLVED - Bulb wattage incorrect.
I had the warning light telling me there was a light out, the rear nearside tail light was off yet a tap on the light turned it on. I replaced the bulb to be safe (excellent position to fit retaining bolts so you can loose them into the frame!) now the light is ok but the warning light is still on. I checked every light on the car and all are working fine. Any ideas?
germulvey is offline Reply With Quote Quote
Old 18-02-2013   #2
Burkina Faso (Upper Volta)
Re: Dash light warning light on - all lights appear working
maybe this tap on the light is causing the issues
never seen one myself
is it hot water comes out or cold
might be best to take each and every bulb out and run the pip on the bulb on some sand paper and to scratch the contacts in the light fitting with a sharp implemen t
this should ensure better contact for the foreseable future and keep dashboard light off
sometimes ive done the above and actually changed every bulb but the light remains lit unfortunately
Likes germulvey liked this post
s and b is offline Reply With Quote Quote
Old 18-02-2013   #3
Ireland
Quote Originally Posted by germulvey View Post
This is taken from a thread i posted on boards
thread ---> http://www.boards.ie/vbulletin/showt...p?t=2056879691
Quote Quote:
2) bulb warning light on is a feature of punto's at this stage, dont worry about it unless theres a bulb actually gone
But yeah its annoying, ya get used to it though, or just take off the dash and put a piece of black electrical tape over it
Car : Fiat Stilo Active 1.6 16V
Mods : full straight through and decat exhaust, HID and LED upgrade, Full 10% tint and 16" sunstrip, Pink hid headlights and 6k foglights
Jamie MK2 is offline Reply With Quote Quote
Old 18-02-2013   #4
Ireland
Thanks all, when i get time a good clean of all the contacts in the light assembly might be worth a shot.
Old 18-02-2013   #5
the tail lights share a common earth which is very small gauge and if you're doing a lot of stop start, night driving in foggy conditions the combination of tail lights brake lights fog lights indicators etc puts a lot of stress on the earth particularlly on the drivers side (fog light side) which gets hot and can melt the plug over heat the contacts causing poor connection etc so if you are cleaning up the contacts pay special attention to the drivers side and pinch the metal tangs in the plug up so they get a good contact, maybe run a thin file between them.
Maker and voice behind the YouTube channel PuntoHowTo 10k subscribers canít be wrong
And now the owner of a shiny new PuntoHowTo Drivetribe
AndyRKett is offline Reply With Quote Quote
Old 24-01-2014   #6
Ireland
Solved my issue:
I had used a 5W bulb on the tail light instead of a 10W !!
In case anyone needs the info the rear light assembly has 3 x P21W and 1 x R10W on each side.
Likes s and b, oldhammer liked this post
(G) No reversing lights / abs light / warning light Scudo06 Scudo 0 23-12-2010 15:44
(T) dash warning light sarahxx Punto (Mk2/2b) 0 02-12-2010 22:49
(T) Help with dash warning light surfstar Ducato 1 24-05-2009 22:30
(T) Mk 2 Dash Warning Light antwist Punto (Mk2/2b) 0 24-09-2007 13:59
(T) Dash Warning Light thomash Punto (Mk2/2b) 9 18-01-2007 19:58
