I Ianwm New member Joined Apr 14, 2010 Messages 21 Points 7 Location Aberdeen Jan 2, 2013 #1 How do I replace the battery in the key I replaced one in my first key but it does not work is there a sequence to follow Ian Last edited: Jan 2, 2013
M momoe Member Joined Jan 22, 2008 Messages 647 Points 132 Location Enfield Jan 2, 2013 #2 No sequence, the remote should work if the battery is good. Check the microswitch as this is a known weak point (usually becomes unsoldered and can be repaired at a good electronic shop). Multimeter would be good to check voltage on fob.
OP OP I Ianwm New member Joined Apr 14, 2010 Messages 21 Points 7 Location Aberdeen Jan 2, 2013 #3 Thanks will try that tomorrow Ian
OP OP I Ianwm New member Joined Apr 14, 2010 Messages 21 Points 7 Location Aberdeen Jan 3, 2013 #4 Checked the battery this morning plenty power so decide to open the first key and study it only to I had fitted the battery the wrong way round Light does not work if battery if fitted incorrectly Both now working Thanks for your reply Ian
