I have a problem with my van and just cannot get my head around it, it all started today when i took the low pressure fuel pump out ( pump in tank ) for a good old clean as it was whirring quite loud sure enough there was loads of crap in the pump, i used some fresh diesel to swirl around the pump and tip it back out i also blew down the two nozzles on top to make sure all the crap got out. Put the pump back in now the van will start then cut out, sounds like fuel deprivation or maybe air? Is there anyway i can bleed the fuel system and or any other suggestions ?
I need this van up and running for work so any reply will be greatly appreciated.
