Right so as you can probably tell I'm planning a Tjet 150 conversion on my Stilo. Suspension/ brake mods will be done during this process or after, depending on how the work flows. Without access to a version of ePER with the new Bravo on it for comparison purposes a lot of my "research" has been guess work so far lol but mechanically speaking everything required (engine, gearbox with mounts, driveshafts and hub carriers) can all be swapped over with little or no modification which leaves the electrical side of things, which is a grey area for me.
From what little information I can gather, I've noticed there is no difference (on the outside) in the design of the body computer/ interior fusebox, internally may be different but I believe I can fit it and use my current dashboard wiring loom with it, if not then the looms can be swapped over easily enough. That leaves the electrics in the engine bay to deal with.
I'm not sure how similar the Stilo is to the new Bravo in this area, but if it has a D4 connector and big purple connector coming off the engine loom like on mine then I'm laughing. If not then I'm going to stick the full loom and fusebox etc off the 150 Bravo into my Stilo.
Bottom line is I'm not sure how similar the two cars are electrically so not sure what Stilo electric bits I can keep or what, but what I am confident in is that I can swap everything from a donor 150 Bravo into a Stilo, time and work I don't mind taking on
I'm trying to hunt down a 150 Bravo donor car, 150 Tjet Grande Punto is a little different to the Bravo so I'm ruling them out.
If anyone is willing to post up ePER pictures of the new Bravo 150, in particular its interior wiring looms and engine bay looms/ fuse box then I'd be grateful
Mark
