Seicento Jef and Seicento Sporting
Seicento 1.2 16v with big plans!!
Ok changes are Black Sporting Alloys, Checkerd Roof Inside and Out, Lowered on 75/55 I think and HID lights
Inside : White leather bucket seats, Poineer Headunit, Poineer 6x9's x 2, Vibe Slick 12" Sub, Sparco 3 Point Harness.
Still some things to do to it the piece of vynal on the side of the puzzle im going to take off and i would like it debadging but thats about it :)
Re: Seicento 1.2 16v with big plans!!
Got my new bottom arms today do removed the bushes and replaced with strongflex
If anyone wants the bushes I took out your welcome to them if you pay postage
Unfortunately the rear drum brake pipe nuts are rounded off
Any advice on freeing these off?
Jeff
if you are lucky, take the whole cylinder off the back plates keep spraying plus gas and wire brush it. And turn the whole cylinder.
But i would just replace that brake lines, assuming you can undo the other end.
Ming
So far I wouldn't say im lucky haha but I will try this at the weekend and also get some new lines made fronts need doing anyway so will do all in one go!
If tank is coming off, there is a joint for the pipes in the middle of the car that goes all the way. I would replace it from there, trying to undo 10 years old union is a total nightmare!!!
Ming
Ming
PLUS
make it fairly straightforward on even 24 year olds.
But if you're feeling flush, replace the lot with aeroquip.
depending on how rounded they are, don't look too bad atm, if spanner is just slipping round one option is to cut the pipe and use a decent 6sided socket. Means replacing pipe obviously.
If i didn't want to cut the pipe and its rounded i would go for my mole grips to hold it and do what Ming said, turn the entire cylinder.
Fuel tank came off today to make access to the brake pipes easier as suggested never taken a fuel tank off before so new experience!
Only make one cock up which is pictured above! Snapped off one of these anyone know if they come with new tank or if I have to buy separate?
I also snapped mine, you don't need it, it's for the cannister !!
Of course with the 16v you are not running a cannister anyway.
I should have asked what it was first! Haha still learning that my excuse! So hopefully tomorrow I'll get the lines off and have some new ones made up, out of interest can you paint copper lines I know the usual route is they get wax oiled but if I painted them would that be enough protection?
