Seicento Chalky, 1.4 16v ITB Seicento.
I don't know if you guys remember but back in january I was starting a project that involved me swapping the piston rods from 8v ones to the 16v ones, fitting a 1.4 8v grande inlet manifold, and a spicy CB cam :D.
Well that got thrown out, and I promised you I would still do a project.
I Delivered:
The donor engine was removed from a 2003 fiat stilo 1.2 16v with only 28k on the clock.
I got the engine home, stripped it down and painted it pretty much straight away (getting quite high in the garage during the winter :D).
Re-assembled with pistons soaking on oil for the next several months.
The next thing that was on the "to-do" list was chassis tweeks and upgrades.
So off came all the brake lines (They were definately on their way out, so it should be on everyones checklist. Please I do advise this), radius arms, rear beam, petrol tank, handbrake cable, wishbones, front uprights, front calipers. I took everything off so that it was just a shell with windows, steering wheel and seats.
Brakelines were all replaced with 3/16 cooper nickel and shiny stainless fittings, finished off with some nice goodridge braided lines.
Rear beam was tidied up, painted and refitted for the new lines to be correctly routed.
Whilst I was doing the brake lines the radius arms were also being tidied up and painted, along with anti roll bar, uprights, and my front upper strut brace.
Then came a nice delivery of my marea rear calipers to go with my PGT front, they got stripped down and wirebrushed right back to the shiny stuff :D. (see the before and after)
Then got a lick of paint again.
A little while went by then a nice postman came again with my fresh polski produce
A few days later another box came from good ole gazzella.
Then my mount plates arrived from Signwerx so I finally got arond to refitting all my back end.
Trial fitted my wheel with the 10mm spacers from the front, Discovred that i'm in need of 15mm at the back due to rubbing on the radius arm :bang:.
And same day I got bored and re-fitted the front too. All finished off by my custom Gaz coilovers on the front, and custom Gaz dampers on the rear (Need a coil chopping out on the rear mind just so the car is nice and level).
The bushes were noticeably stiffer even off the floor, no give or flex in the material at all. I theory with some decent tyres this car should stick to the floor nicely (y).
nother payday was coming up so the head got some attention in the form of a dremel, dividers were thinnned down, ridges ground out, drill marks were ground out and smoothed, and to finish off. Hand sanded all off it smooth with good ole 80 grit for the inlet, and outlet was smoothed out finer and spent a few hours polishing till bling bling :cool:.
Valve hole on the right shows what it was before grinding, left shows part way through grinding.
Never got any photo's from that night of finishing it off but It will improve flow no end (I hope :rolleyes:).
Next day it went to my local machine shop to have a couple of new guides fitted, skim, and reseat with new seals.
Inlet:
Exhaust:
A trip to another fairly local machine shop resulted in:
1.8KG taken off the stilo flywheel, balanced with the clutch (happy days :D)
Got home that night and decided to make a hesitant start on re-fitting the head :cry:.
I've never poo'ed myself so much tightening bolts up.
Was all fitted without so much as a sqeak (followed adived and gently wiped engine oil on the bolts).
So happy after that I then fitted my manifold and oil filter.
Then began painting my head and fitted it next day along with water pump pipe from the old engine (new seal, again advise checking quite oftenly).
Timed up and ready to go in :D
Then postman came again (y). Hello drilled and grooved.
That Weekend came, so did my friends brother (whom I owe a drink (y)) and something magical happened in a few hours.
We did manage to break my new crank sensor in the process mind :bang:.
Sexy ;)
Then I struggled a little for and inlet manifold but then I managed to source one from a fiat breaker then along came Kritip to help me with the wiring (thanks again bud (y)). Spent the last few days finishing that off and last night it fired up for the first time in 5 months.
Made some awesome bangs before hand though due to us having the coils wired backwards (oops), quick swap of the leads and it fired up first time (y).
All that is left to do now is get myself a set of new tyres, get over to custom chrome in the morn and get my new front exhaust section made (yes we started the car up without and exhaust, sounded nice and loud :tempt:) Cov69, and kritip both were witnesses to the start up :D. Thanks again guys for your help.
Ohh before I forget, here some pic's of the new wiring for the battery, starter, and alternator:
Hint, it's the big thick one without the fuse on it :D.
Here's where i'm up to, i'll update this soon :D.
Re: Chalky, The 1.2 16v Sei
That looks amazing, im thinking of an engine swap my little Sei goes all over the shop and the 1.1 needs a bit more ooommmppphhhh as I noticed when I drove to Paris the other week.
Is there a 1.4/1.6 lump that goes in easy.
Are you using the sei MPI ECU ?
Is it possible to remap the sei ecu to cope with the engine tho ?
Ming
Yes i'm retaining the Sei ECU, and just re-wired the parts needed. Kritip ran his 1.2 swap without a map fine but i'm getting mine done as soon as I get the moulah :D.
As goes for 1.4 swaps check out the FAQ's, they are pretty much the same in terms of fitment and wiring but that you would need to swap the ECU too, or atleast go aftermarket.
Wll today saw some great results, Kritip popped back round with him cam locks so we could check the timing over. So far that appears to be ok, but we are going to strobe it to double check.
Car sounds like it's running on 3 but theres spark on all 4 cylinders so we are going to try a different coil pack and leads to see if that fixes anything :confused:.
The car is now back on the floor, but the back end is sitting too high so that will get some treatment in the form of a grinder :D. The front is setup to just how I like it, but the liners may need to come back off :bang:.
Oh and I need to sort the throttle cable out too, delayed response is mostly due to the cable sagging and dropping all over the arm :D.
Anyway enough jabba.
(Alsmost desktop worthy)
If somebody would be nice to donate me a new PAS side indicator unit that would be mint :D.
I did an engine swap on Brava and when it was all up and running, it was running on 3. Turned out to be a dodgy wire on one of the injectors. Check them too, it needs fuel too ;)
Well officially I finished the car on the saturday before Mod Nats due to my alternator problem but touchwood that is solved (hopefully permanently fixed).
A photo of chalky at the show too :D. My missus hiding behind :D
Then the monday after I decided to get my amp back in and connected up for my speakers. I've tidied the wires up since, and people will be glad to know that the amp is not for subs, and no subs will ever go into the back of this :D.
Finally some photo's with the suspension settled a bit more
Garfield on board :D
:O is that a lower brace i spy ? You gonna slam it to the floor as well???
Ming
That is as low as I would comfortably go :D. Strut brace is about 1" from the floor, I can't go over the individual speed bumps anymore. Have to scoot through the middle of them or go over as close to the curb as poss :D.
It's lower than you think, the pic's don't do the height any justice.
Handling wise it sticks to the floor, no more body roll, and can plant it properly on the way out of corners (y). But the sport polybush helps heaps too, and the yoko's were a good choice aswell.
Ah nice to hear :D, just becareful with it and don't hit anythnig hard :p.
Am thinking of getting one fitted, but think i will get it modified and have it raised up a little!
Ming
sweet build mate well done it looks the bizz and is nice and subtle
only thing i would change if it was my would be the rear lights but its your car and it looks great
i love the way you painted all the suspension arms and ARB think i might do that to mine when i am ready to start the strip down and rebuild
I'm happy as chalky got a photo taken at the MIJ Performance open day :D.
I think chalky should of got a proper open bonnet photo though, but they didn't ask.
Funny as Bedworth is in the shot too and i'm sitting inside (y).
