Cinquecento me any my cinquecento
been spending too much time on this car now :p
head skimmed and put back together with new items such as plugs oil, filter thermostat
didnt fire up first time, spark plugs on wrong way around :rolleyes:
after i had it all together there was a water leak from the o ring onto the block, some what typical after that leaking for around the water pump, done those today but i could still be leaking from around the pump
its leaking some fluid possibly oil or water that picking up oily dirt off the block, comes out more after the engine is turned off then stops
to top that the engine i sold i could use with,k rather ironic i must say as there is a tap from the top end and the cam bearings didnt look there best
Ash
all sorted :slayer:
was the rocker cover leaking over the cam pully end and leaking down out of view and then moving across ontop of the water-pump making it look like the block to head was leaking
some little :tosser:s kicked a ball and it hit the roof,,, luckie i didn't get to it first otherwise they wouldn't get it back in one piece like the other one ;)
best bit was ive finally got to work on my own car today:slayer:
Ash
New owner is me! :D
Funny how things come around eh... Pure chance i stumbled across this thread
