Old 07-04-2008   #16
fia
pingu has donated!
Re: Project PT Cinquecento
ye keep us ypdated with pics mate
fiat stilo 1.6 2002 dead and gone.
1999 seicento sporting.
pingu is offline Reply With Quote Quote
Old 22-04-2008   #17
Got my crane yesterday engine ready to come out at the weekend
lui.c is offline Reply With Quote Quote
Old 22-04-2008   #18
I Need Beer
allanhelen's Avatar
allanhelen has donated!
That engine does look big when you see the car minus the bodywork good luck sqeezing it in.
What are you planning ECU wise are you keeping the Punto ECU & loom or are you going stand alone?
No FIAT's any more and nothing else sensible either
allanhelen is offline Reply With Quote Quote
Old 22-04-2008   #19
The plan is to keep it as original to the gt as pos, same fuel pump/ecu/ brakes and instrument cluster just to keep it fault free, I hope! May go to cable clutch, just looking to see if a mods out there for hydraulics.
Old 22-04-2008   #20
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Skate Boarder Champion
nice to see someone doing another big project with a fiat, few going on the forum now Good luck mate, and keep the pics coming
Finn - Panda 100HP - thread
Oberyn - Suzuki Ignis Sport - thread
Some previous cars: Alfa 159, Bravo HGT, Cinq 16v, Sei Turbo, Punto GT, Panda Mania 1242 mpi
blu73 is offline Reply With Quote Quote
Old 22-04-2008   #21
looking good so far, i had to completely strip a gt3 last year and toyed with the idea of what your doing. Where bouts u from mate? make sure u get plenty of pics
Things to sort out include
GT clutch is hydraulic, cinq is cable. GT gear shift is rods, cinq is cable
Here are a couple of reference pics that might help you on your conversion mate, its not mine but another members pics that i found could be helpfull
You can see how close the engine sits to the chassie leg, two small marks in the pic are where a 2"-3" section will be cutout for a engine mounting point
in this pic u can see where the dizzy sits which is very close to the slam pannel
Quote Originally Posted by BeArDy View Post
UPDATE....
well engine is in the bay with all cutting mods done.
Started to make the rear engine mount and worked out how to make the other 2.
Cutting mods are as we all know the drivers side leg (Photos to follow). you need to open up the box section (no need to remove it all) and the cut about 2-3" gap out so the standard Uno mount will slot in. Also remove Battery tray.
you also need to bang down a lip on the passenger side there the chassie rails meet the front arms, as you need the box to fit further back (only a 1-2")
Front gearbox one looks like i can use another rubber which came off the rear of the standard cinq (as its shollow) an make a small triangle braket.
Rear Gearbox mount looks like i can use the standard Uno rear gearbox and extend is which works out around 3" .
Other things i have found the Uno box is hydraulic BUT its only a hydraulic system with moves the arm rather than a release baring. I removed all the hydraulic mounts from around the top of the box and all the parts there are for cable. I can eather weld a new section on the Clutch arm OR find on it a scrap yard as it just unclips.
Now the engine is in the bay i can see i may have to mod/cut some of the slam panel out as the dizzy cap is very close but more of a update when the engine is fully bolted in.
stevecnet is offline Reply With Quote Quote
Old 22-04-2008   #22
Trader Rating: 1
scrap the dizzy and use an electron ignition system
Brooky is offline Reply With Quote Quote
Old 22-04-2008   #23
fia
pingu has donated!
cam belt dnt look 2 good.lol
cant wait to see it finished.
Old 22-04-2008   #24
^^^Joker
CinquePunto's Avatar
CinquePunto has donated!
Quote Originally Posted by Brooky View Post
The punto GT works on an electronic ignition coil.
Good luck with the project mate - it's gonna be a tight squeeze though once you have the turbo in. The worst part will be routing the intercooler pipework and AFM (aswell as fitting headlamps etc)
CinquePunto - Five Point Photography - Adam
CinquePunto is offline Reply With Quote Quote
Old 23-04-2008   #25
Ace project!! Make sure to keep the thread updated!!
You gunna use the Cinq as a fast road car?
fatty is offline Reply With Quote Quote
Old 23-04-2008   #26
I second that blu !!
Bring it on corsa's !!
Fostar is offline Reply With Quote Quote
Old 23-04-2008   #27
Just another nutter
Munkul's Avatar
Munkul has donated!
Quote Originally Posted by Punto_Rich65402 View Post
no because the punto is the best fiat avalible
you are probably going to die... hope you have a handy police force
Munkul is offline Reply With Quote Quote
Old 23-04-2008   #28
Quote Quote:
And thats your opinion, but as your on the FIAT FORUM and not the PUNTO Forum, you will have to put up with the cinq/sei crew.
And as for the engine swap, it is a lot more difficult swap to put it into the cinq, so the end car is a lot rarer than a converted punto, and at the end of the day aint that what modding cars is all about - having something different?
Likes simo101, bluecinq94 liked this post
ginner is offline Reply With Quote Quote
Old 23-04-2008   #29
just frank
stilosporting's Avatar
Trader Rating: 5
stilosporting has donated!
why put a punto gt engine into another punto? just buy a gt.
why put a coop engine in a punto? because it would be sweet as. (would prefer it in a stilo though)
why put a punto gt engine in a cinq? see above
stilosporting is offline Reply With Quote Quote
Old 23-04-2008   #30
Jaaaag man.
Puntoboy's Avatar
Puntoboy has donated!
Quote Originally Posted by stilosporting View Post
I can name a few reasons why you would put a PGT engine in another Punto.
MY15 XF R-Sport Sportbrake 3.0 IRR / Black Pack / Winter / Parking / Mirror / Keyless Entry / Adaptive Dynamics / Dark Dracos / Carbon Veneer & Mirror Caps / XFRS Carbon Diffuser
Puntoboy is offline Reply With Quote Quote
