Traffic announcements on Croma stereo (maybe others as well)
swebb
UK
Very loud - is there a way of reducing the volume? I can't spot anything in the manual.
on the stilo if you hold down the audio button (or the one near it - i can't remember) for a few seconds you will find a sub menu for settings
basically hold down some of the buttons for a few seconds and see what happens
sorry its too cold to go outside to see exactlywhat button it is!:D
I remember that on my previous Stilo. There's no menu like that on this stereo. There must be another way...
It's that loud that it made my daughter jump when she was alseep in the back!
Same issue on my Panda:( . Default min volume for TA is 20, I would normally listen at something like 8 - 10. The only solution I found, well partial solution anyway, was to go to the user defined graphic equaliser setting and set all the 'sliders' to their minimum which has the effect of reducing the volume across the range -but also probably reducing the quality and definition of the sound as well. Now I can listen to the radio comfortably at about volume of 12 or 13 and the TA when it comes in at 20 is less of an increase on what I've already got.
I would have thought that a default of 10 minimum would have been more suitable - at least in the Panda.
