DJ_Bucho
Established member
My dad (Julio_scorchio) and I want to fit a recently purchased Greddy Turbo Timer to my dad's Turbo Cinq but we've come across a problem. . . . .
In order for it to work properly it requires an electrical speedo signal, however the speedo on cinq's is driven by a cable connected directly to the diff, and this therefore doesn't give any sort electrical signal.
The problem is if I us an electronic sender (from say a punto) and connect this to the diff in place of the speedo cable, yes I will get an electrical signal for the Turbo Timer, but the speedo cable wont have anything to plug into and the speedo on the dash will stop working = NOT GOOD
Having searched far and wide I've found the thing I think I need, see below
http://www.classicchevy.com/product.asp?pf_id=19-07&dept_id=1834
Its an Autometer Hall Effect Speedometer Sender Unit (Part number 5291)
From what I've read this unit (in my case) would screw onto the diff and then the manual speedo cable would screw onto the top of it. Meaning my dash speedo would still work and I'd have an electrical signal for the Turbo Timer to use.
However here goes the other problem, where on earth do I get one of these from, I've tried everwhere and can't seem to find anyone in the UK that sells them, I've searched the web high and low, and now one even seems to ship to the UK.
I was just wondering if anyone knew of anywhere that sells these, or has tried fitting an item similar to their car, or knows of a better way of doing it?
All help very much appreiated.
Brian
Brian
