J333EVO said:
So if you have a Mk1 UNO keep hold of it is a slowly disappearing car.
*Chas wonders if his 20 year old Uno will still be solid metal by the time he gets back home in October...*
Unos are weird, because some rusted to bits like no tomorrow, while some kept off rust for ages. Patchy quality control and variable steel quality methinks. I've definitely noticed that early mk1's ('83 - '85) dissolved before your eyes, yet some of the later mk1's ('86 to '89) lasted very well (other than the door bottoms!) The exception seems to be the turbos, and one theory is that the extra power/ torque flexes the shell more leading to cracking seams allowing water ingress and hence rust. Probably explains why some of the base models didn't rust much while the turbos did.
Also of note is that the early mk2's seemed to be bad for rust (see Duncs Turbo re-shell!) Even base model mk2's rusted far worse than later mk1's, yet the last few years of the mk2 they seemed better. Door bottoms were a definite weak point though on all years, and it took me ages to find some for mine that weren't rotting merrilly away.
Worth bearing in mind that Unos were cheap cars, and cheap cars tend to get run into the ground and don't have much care or money lavished on them when they get older. Much like the Skoda Estelle/ Rapid, which were actually quite solid little cars.
A Porsche 924, though little more than a VW/ Audi parts bin special (wasn't it originally meant to have a VW badge?) is seen as a sports car with Porsche heritage therefore it tends to get looked after more and also restored, hence a greater percentage still being left on the road.
Someone mentioned the mk3/ 4 Escort, and that was a model I remember being terrible for rust. Yet some of the mk3 Ghias stayed in remarkably good shape, while the lower models (XR3's included) rusted terribly. With the Fords, it all depended on where they were built, as I'm fairly sure that the mk3 Ghias were made in Germany and the other models were built elsewhere. The same applied to the Capri, as the German Capris (2.8 injections and some of the other variations) were always better built than the lower end models built in the UK.
This is similar to the mk1 Cavalier/ Opel Ascona. The Cavaliers were built in either Luton or somewhere in Belgium, while the Ascona (Cavalier with a different nose) was built in Germany. The Asconas always lasted better than the equivilent Cavaliers.
One car I'm surprised to NOT see in that list is the Vauxhall Nova. That was a poorly built car that rusted badly and you hardly see ANY left on the roads now. They were built in Spain and were shockingly assembled! Then they were shockingly 'modified' by the Chavs and thrashed within an inch of their lives...
Either way, my little old mk1 Uno 45S is probably rarer than a Uno turbo! I'm going to hold on to it because I still love it to bits
:slayer:
