pandaluvah
- Aug 2, 2006
- 2
- 2
Hi:
We have a 1989 Panda 1000 CL from Germany. It has been running fine for the past 17 years, but lately the carburator (manufacture by Weber) had started to act up. We often have to pull the choke out for even a 10 km trip or the engine would stall.
Our mechanic (in Rome, Italy) tried to install a second carb from another Panda, but for some bizzare reason, it did not fit. Nowhere could they locate a similar carb.. There is no visible wear and tear on the valves, but we haven't ruled out that may be the case. The mechanics couldn't find the adjustment screw, either.
We are wondering, if (a) anyone knows how to adjust the air flow into the Weber carb, or (b) if there is a compatible replacement carb which we can use for said Panda model.
Thanks very much in advance,
Pandaluvah.
Pandaluvah.
