guys i'll tell u a story of a problem happening in my car(fiat 127 MK3 903cc) since the last 5 months! and i really need ur help!
5 months ago the car suddenly started to shake at high speeds (100-120km/h)...i expected it was wheel balance and alignment....but i was intending to change the original wheels with new alloy ones with wider tires...so no need for balancing the original wheels now...a week after i installed the new shoes ...and the shaking was still present even after balancing all the 4 wheels and alignment of them for 2 times!!
i did every thing u could imagine to eliminate this shaking but nothing happenned:
1-changed front discs and pads
2-changed the long drive shaft, as it was bent( i thought this would be the solution)
3-checked the suspension and everything works fine.
4- for experiment i did the following:
i raised the front of the car and ran it on 120 km/h the shaking was present..
i removed the wheels and ran it again the shaking was still present but very weak..
i drove on a high way till i reached the shaky speed, disengaged the gearbox and switched the engine off...it was still present!!!
knowing that the steering wheel is shaking insanily as well during the shaking of the car..it is something related to the drive line but i dont know what it is...
sorry for talking so much and not being very well organised..
im in favor that some of u guys may have faced this problem before or could know the possible solution fo it..
thanks in advance
thanks in advance
