1242 16v turbo forged pistons anyone?
Maidstone
HI
I just wanted to see if anyone is thinking about turbo-ing a 1242 16v and would be interested in a set of forged pistons? I have been talking to the guy who made the french 16v turbo cinq and I have made arrangements to have a set made@£600 but for another £50 can have another set made. If anyone is interestred please contact me as we can go halves and it would only cost £350 a set each which is dirt cheap. Please phone or text me on 07890 412031.
Cheers Rich.
would i be right in thinking the 16v pistons would fit the 8v block. they should shouldnt they. if so, i'm interested and i can think of two others who might be
They wont fit striaght in because Im having them made slightly oversize to get a bit more cc and because my block is worn slightly. You would require a rebore but I can arrange this cheaper for us all if a few of us did it together or you can have that done yourself. The pistons would probably be even cheaper if more than 2 of us did it. I have a spare 1242 8v block I could get rebored and then we just do a swap if thats any good? It would be really good others had it done too cos it would save us all a fortune compared to having it all done separately.
Yeah it is the same block- the 16v pistons have 4 slight cut outs fot the valves instead of the 8v's 2 but that should not make any difference once in the block.
I have had a chat with the guy making them and told him I need to reduce the compression ratio as the engine is not turbocharged from the factory and he is going to work out how much dish they need. I just need to provide a standard piston and tell him the standard CR and he will do the rest. He suggested a 0.5mm overbore as this will totaly take out any bore damage and ensure the bores are round not oval and also give a worthwhille cc increase.
