| Thread Tools |
![]() | #1 | ||
Posts: 10 Thanks: 0 Trader Rating: 0 | Got my licenece & now car wont move Hi! In november i passed my test, and unfortunatly, due to being short of cash, i was not able to insure my car :( Anyway on friday i was offered a job starting dec 10th, so my mum decides to let me insure my car in my name, basic thrid party,so i can get to work (naturally :P). So, with everything looking great i thought nothing could possibly go wrong Anyway, after we get the insurance done, i decide to take my car for a spin. get in everything is fine, except for there is no biting point or stiffness on the clutch. so i tried putting into 1st, 2nd 3rd 4th 5th reverse, and it wont go into any of the gears when the engine is running. The handbook says its a self adjusting cable clutch, and it shows a small diagram of what it looks like. Problem is, its impossible to find. Anyway, to sum up, my cars clutch (which was alrite the alst time we used it) doesnt work, and the car wont change gear. Ive got very littl e money and cannot afford to have the car town away to a garage. Can any of you guys please help, because i really need the car for wednesday, as this is when my job starts. if anyone knows anything please help me, im really desperate ;) any info would be great. Thanks a billion times in advance!! oh btw, the car is a 1990 1.6 Fiat Tempra SX 'tetra' A R C
![]() | #2 | ||
Posts: 10 Thanks: 0 Trader Rating: 0 | please please help. any any advice i would be most greatful for. pleeeeeeeeeeeeeeeeeeeeeeeeeeeease helpB):( A R C
![]() | #3 | ||
![]() | will it go into gear with the engine off?does the clutch just go straight to the floor with no resistance compared to the last time it worked?dont know tempra,s but the adjuster will either be at the top of the clutch pedal(might have to climb right in the drivers footwell) or it will be at the point where the clutch cable connects to the gearbox(at the passenger side of the engine)if the cable has snapped or the adjuster has broken you should see it.hope this helps if not write back on the forum[8D] The Fiat Cinquecento Fun While It Runs
![]() | #4 | ||
Join Date: Jun 2003 Location: Pontefract, United Kingdom.
Posts: 678 Thanks: 0 Trader Rating: 0 ![]() | Im not too sure but think your clutch cabl could of snapped!! you can fix it yourself just a bugger to do i think im not too sure, some one will be able to shed more light (sorry if this was no use at all;)) James www.clubcento.co.uk
![]() | #5 | ||
Posts: 23,467 Thanks: 1147 Blog Entries: 3 Trader Rating: 1 ![]() | Your clutch has bonded itself to the flywheel due to lack of use. Get the engine warmed up, switch it off. Put the car in the road by whatever means, belt up, and then start the car in first gear. The car will drive off immediately you turn the starter, but once it is moving by engine power, pump the clutch pdeal until it releases. This needs to be done on a quiet road as it can be dangerous. If it does not clear the first time, switch the ignition off and select reverse and do the same. Cheers David
![]() | #6 | ||
Posts: 10 Thanks: 0 Trader Rating: 0 | Thanks guys, you're advice is most appreciated. Well, when the engine is off, you can change gear. When you turn the engine on, and press the clutch right down, you cannot get it into any of the gears, and when you put it in reverse, it grinds! Wehn you press the clutch, you can only feel a tiny little bit of tension right at the very bottom, but alas its not enough to get it into gear:( ive looked in the engine bay of aaages, and cannot see anything, even with the torch:( i'm really really worried now *cries* :( A R C
![]() | #7 | ||
this is where i stand Join Date: Oct 2003 Location: Manchester
Posts: 13,581 Thanks: 289 Trader Rating: 0 ![]() | have you tried what rallycinq has suggested? Cinq Sporting - and yes, its broom yellow!
![]() | #8 | ||
Posts: 10 Thanks: 0 Trader Rating: 0 | not yet, as i have only just read it!!! when i replied or reply he must have been writing his reply!! thanks mr rally!! its a bit busy and dark at the moment, so i shall try it tomorrow, before the rush hour!! thanks alot:) [^] p.s i shall report back on what happens thanks again!! A R C
Thread Tools | |
Scheduled Move Time | ben | Latest News | 4 | 26-06-2004 19:50 |
The Move Is On! | ben | Latest News | 17 | 09-06-2004 17:35 |
![]() | Samtimmons | Cinquecento / Seicento | 10 | 07-06-2004 20:27 |
Things move quickly on the FiatForum | MikeWhitcombe | Leisure Lounge | 6 | 14-05-2004 16:18 |
Server Move Complete! | ben | Latest News | 3 | 31-01-2003 20:50 |
