Variable rate springs from Bilstein would be a good bet but also fit good bump stops. The snag is that most performance springs are stiffer than OEM so likely to make speed bumps even worse.
Standard springs and dampers with good bump stops. Avoid running the shocks until they leak as their damping performance degrades long before they are bad enough to fail the MoT.
