Hi All,
Fiat qubo battery light stops on, I have 12.6v across the battery and the alternator is changing, any ideas please
12.6v across the battery before you start the engine is fine.
12.6v across the battery with the engine running is not good. With engine running, you should see around 14v, the desired range being 13.6 - 14.4v.
You say the alternator is changing, which is an interesting phenomenon, I guess that was a typo and you mean charging. So what is the charging voltage? If only 12.6v, it is likely a new alternator is required, but all connections need to be checked first.
Yes..Could you explain - do you mean disconnect leisure battery.
