Old 3 Weeks Ago   #1
Unhappy Not turning over smoothly: your first guess?
Hullo, I'd like to know if anyone has a suggestion, from experience. The engine of my Fiat Punto is not turning over smoothly, it sounds and feels bumpy. Last week I wondered if I was imagining it (this is my first automatic car so it's not first nature to me). Foolishly I didn't get it looked at before driving from Reading to the Wirral (where I now am) and it got worse on the way - particularly noticeable when pulling away or going up hill, so in low gear. I have found a garage who will take a look at it on Monday morning, but I'd love to know if it's a typical Fiat Punto problem that rings bells with anyone.
(Last time I had a problem, it got diagnosed here and I had to TELL the garage what the problem was! And they fleeced me royally, but that's another story.)
Fingers crossed it's something minor like spark plugs and not the incipient demise of the car... It's a Fiat Punto Dynamic Speedgear, 2003.
Hellohelenhere is offline Reply With Quote Quote
Old 3 Weeks Ago   #2
Re: Not turning over smoothly: your first guess?
When was it last serviced?
What are total miles on car?
Any record of last time spark plugs changed ?
Jack
jackwhoo is offline Reply With Quote Quote
Old 3 Weeks Ago   #3
Trader Rating: 1
portland_bill has donated!
Quote Originally Posted by Hellohelenhere View Post
That'll be the 1.2 16v 80hp and CVT gearbox. (I still miss mine)
Lumpy engine could be ignition, or head gasket.
Ignition is common, coils pack up, as do plug leads. Also the main plugs on the ECU need to be checked to ensure no loose pins.
Most common issue is plug leads. If needed get a good brand name, such as NGK.
Likes varesecrazy, mowermender70 liked this post
13 years motor trade, 16 years motor industry. 16 years Driving Instructor & 9 years Fleet Trainer
Panda Alessi (2015 Skoda Fabia)
portland_bill is offline Reply With Quote Quote
Old 3 Weeks Ago   #4
Thanks, Portland Bill! I hope it's plug leads. Head gasket sounds alarming. :-o
Old 3 Weeks Ago   #5
varesecrazy has donated!
Hi Helen
@George Pogg
May be of some assistance if you are struggling.. local to Wirral
Charlie ( nearer Reading..)
Old 3 Weeks Ago   #6
Check oil and coolant levels
2 minute job that could answer your question
You might even spot a hose fallen off while looking..
Do keep us informed
Charlie
Old 3 Weeks Ago   #7
Ha, thanks Charlie! I did check those (in a sweaty panic) when the problem was getting worse and I was halfway between Reading and the Wirral. But they're fine. Petrol tank also full. So it's not any of THOSE things. Will let you know what the mechanic says tomorrow morning. (Found a nearby garage who said they'll take a look). Wish me luck!
Old 3 Weeks Ago   #8
Does it 'idle' in neutral ok ?
Underload with an auto can be tricky..
But with no load it should be fine.
I hsd a CVT uno..1988
There were lots of small hoses around the carburettor.. if they perished.. it behaved poorly
Depending on the age of your punto..
It should be 'managed' by a computer ( ECU ) which can often 'mask' poor running through small eroors
Time will tell
Good luck
Charlie
Old 3 Weeks Ago   #9
Saga continues. I took it to a mechanic on the Wirral who reckoned it's probably spark plugs or coil packs, but would have to order the parts; thought I was probably OK to drive it back to Reading. However, round about Leominster (I prefer the scenic route!) it got pretty juddery. Stopped and called Green Flag (there is some kind of juju which makes it start raining as soon as you break down by the road), who came and made a similar diagnosis, but it's 'not something we can fix roadside', at which point I discover I've only got the 'tow you 10 miles maximum' Green Flag cover. We decide I'll try to limp onwards, and I change my destination to Chipping Norton (where my Dad lives) instead of Reading. Nail-biting drive at 30-40 MPH, gets me to Chippy 5 and a half hours after I left Bishops Castle. Dad has looked at this morning; it's only firing on 3 cylinders. To be continued.
Old 3 Weeks Ago   #10
At least you are safe
Get your dad to pull off 1 plug lead from The coil pack at a time..
If it drops to 2 cylinders.. thats a good lead
No change means its the correct cylinder that is not firing... that plug or lead are the problem
Do you have an engine light on now?
Charlie .. Didcot
Likes mowermender70 liked this post
(T) Not shifting smoothly between gears? Blank2k2 Punto Evo 1 03-06-2018 08:48
(G) Not idling smoothly newellan Multipla 4 19-01-2017 09:00
Just when everything is running smoothly... pooroldcodger Computing 2 08-05-2013 17:06
(G) Not driving smoothly GJL Punto (Mk2/2b) 10 26-10-2011 17:05
(T) Fiat GP want start smoothly generalns85 Grande Punto 11 30-06-2011 13:01
