I have recently purchased a fiat doblo 1.3.
There is a snapped glow plug in the head.
If it starts dont worry but I strongly recommend you get all glow plugs changed because when another one fails you will struggle to start the engine.(just seen you are doing that
until the engine fan comes on, the engine tone changes,
This is probably the additional electric load of the cooling fan
it misfires on rev limiter if you hold the accelerator,
A soft rev limit is normal. But doing that will not do the engine any good at all. Diesels do lot like running at max revs.
Black smoke from exhaust from acceleration only when accelerating, dosnt smoke when reached speed, the smoke stinks like oil or diesel and it chokes u in the car(if im deiving around hard up too 3-4k rev each gear it really stinks, partner says it makes her get a head ache.
(1) You are revving the engine more than necessary. Diesels will accelerate faster if you dont max out the revs. You will have 80% of max torque from about 1800rpm to 3500. Torque falls off rapidly above that speed.
(2) Black smoke means not enough air. If the air filter is clean you need to thoroughly check the inlet system and turbo. It might be clogged with soot. The turbo could be failing.
(3) Do not trust free revving smoke tests. They give a false indication of smoke as very little fuel is needed to spin the engine. If that IS throwing black smoke you really must investigate the intake system.
The rev needle is coming back too idle it hangs at 1200rpm for 2seconds before slowly dropping back too idle.
This is normal
. The fuel supply is cut to zero when you lift the pedal. Fuel flow drops back in, just above tickover to avoid it stalling.
The fan comes on some times even if the engine isnt fully heated up, never comes on cold, as soon as it turns off car runs normal again.
I sometimes turn the car off for 30 seconds and then the fan dosnt come back on for a while. Would this be related too the glow plug?
Nothing to do with glow plugs could be a faulty temperature sensor.
I'm worried not going to get this fixed and there is a bigger problem.
DPF will be damaged if engine is smoking. But does you engine actually have one? BAsically the DPF is built to handle normal levels of soot. It will be overloaded if engine is running badly for some reason. The air intake system must be 100% to avoid problems.
