Today a message warning appeared saying excessive radiator fluid. I assumed this was because the engine was too hot or overheating. Topped up water. But then realised heater inside car was blowing out cold air and not warm despite it being on warm setting.
I was wondering if there is a link to the warning light?
It only came on once and not appeared since.
I took the car to garage as precaution and the said something about a possible leak. They are running a diagnostic to find out and will get back to me regarding any work.
Has anyone else experienced cold or cool air blowing from heaters even though set on warm?
Also garage said of there is a leak that if work needs to be carried out it would also need the belt replaced which I did not expect.
Does anyone know if a belt would also need to be replaced as weLloyd as water leak sorted?
Is the heating water system linked to this belt?
Many thanks
Many thanks
