Old 10-03-2019   #1
Proxy alignment
Mileage flashing on my Punto Evo.
Have bought cables and software, only concern is this:
Anybody ever needed to do this as I donít have 5 digit code?
ssbnreso is offline Reply With Quote Quote
Old 10-03-2019   #2
Pugglt Auld Jock has donated!
Re: Proxy alignment
Me too! Proxy alignment is one of the few things I've come across when exploring MES that is a bit of a mystery. I don't really understand what it does or when you would use it. Also it seems always to be accompanied by these frightening (to me anyway) warnings.
Pugglt Auld Jock is offline Reply With Quote Quote
Old 10-03-2019   #3
Trader Rating: 1
portland_bill has donated!
Re: Proxy alignment
I've done a few on others vehicles.
All the various computers and 'nodes' around the car need to talk to each other, and accept each other. A proxy alingment tells them all to accept each other. This is used when components are changed, or when communication is lost for some reason.
As an example, a friend replaced a complete door on a Croma. As window switches and locking are contained in the door, there is a 'node' in it. From that moment, all functions worked, but the mileage was flashing. A proxy alignment sorted that and all is working well since.
A proxy alignment will not fix any causes. They need to found and fixed first.
There is always a risk with this sot of thing that communication will be made worse, hence the warnings given. I've not seen the warning above, but the code can be obtained from your Fiat dealer. They charge for this, anytihng from £15 to £50, so be prepared to shop around or negotiate. Need to supply proof of ownership.
13 years motor trade, 16 years motor industry. 16 years Driving Instructor & 9 years Fleet Trainer
Panda Alessi (2015 Skoda Fabia)
portland_bill is offline Reply With Quote Quote
Old 10-03-2019   #4
Re: Proxy alignment
Quote Originally Posted by portland_bill View Post
Thanks PB.
So, I suspect, this would be a main dealer ask? My wee Fiat independent specialist wouldn't be able to supply this code? Not too frightening a price, but £15 sounds much better than £50! I might just stick my head in the MD's door and sound them out next time I'm passing their door.
Old 10-03-2019   #5
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: Proxy alignment
You don't have to reprogram the indicator and and alarm mode unless they are different from the factory default. You can check the current settings before carrying out Proxy Alignment. Even if they have been changed, the default settings should still be OK in most cases.
Some cars came with the CODE on a credit card sized card. Check your document wallet you might have it.
Robert G8RPI.
g8rpi is offline Reply With Quote Quote
Old 10-03-2019   #6
Re: Proxy alignment
Quote Originally Posted by g8rpi View Post
You don't have to re=progrm the indicator and and alarm mode uness they are different from the factory default. You can check the current settings before carrying out Proxy Alignment. Even if they have been changed, the default settings should still be OK in most cases.
Robert G8RPI.
Thanks,
Iíll have a look at settings.
Old 10-03-2019   #7
Re: Proxy alignment
On the EVO they did not have an alarm in the UK and seeing as they are all right hand drives they were specifically build for the UK therefore the default was that they did not have an alarm.
I seem to recall that the indicators command relates to if the alarm goes off will it flash the indicators or if the alarm is set will it flash them to tell you. Again the Default on UK cars is to flash the indicators when you lock the doors on the remote.
This should not change things as the defaults are set but if you had for exampled turned off the indicators when locking the doors then you might find they start flashing again.
Another thing you could change was the no seatbelt chime which I believe will also default back to working if you do a proxi align.
Maker and voice behind the YouTube channel PuntoHowTo 10k subscribers canít be wrong
And now the owner of a shiny new PuntoHowTo Drivetribe
AndyRKett is offline Reply With Quote Quote
(T) Proxy alignment henseyseries3 Punto (Mk2/2b) 1 18-12-2017 23:59
(T) Proxy Alignment bfbenf Grande Punto 4 18-10-2017 17:58
(T) Proxy alignment steven45610 Punto (Mk2/2b) 15 14-08-2013 11:00
(G) Proxy Alignment bredsticz Punto (Mk2/2b) 8 14-05-2010 00:34
(G) proxy alignment leo t Punto (Mk2/2b) 1 25-06-2006 13:48
