Thread Tools
Old 07-01-2018   #1
USA
1969 Italia Intermeccanica / Fiat
Help please. I am desperate to identify a Fiat part that is on my 1969 Italia Intermeccanica restoration. I must find the steering column mounted switch gear assembly (turn signals, etc). An arm and some of the internals on mine are missing and / or not capable of repair. If I knew the make and model I am sure I could find one, so perhaps someone here can identity this or even maybe a source.
I have scoured the internet over and over looking to see what make and model of Fiat it came on. It is definitely a Fiat part. If you look at the picture of the forward end of it, you can see that it is not round but D shaped, It indexes into a D shaped bracket stamped FIAT that attaches it to under the dashboard.
There must be hundreds of these out there from the late 1960s.
On the bottom are the following markings: (as best I can read them).
VITALONI BRATELLI
BREVETTO INTERNO
Torino
Photos attached. (one arm is missing from the unit shown)
Thanking you so much for your help.
Ron
ID:	187406   Click image for larger version
ID:	187408   Click image for larger version
troutmalt is offline Reply With Quote Quote
Old 07-01-2018   #2
Trader Rating: 1
portland_bill has donated!
Re: 1969 Italia Intermeccanica / Fiat
The first picture is the badge of a Triumph. Like these.
https://rimmerbros.com/Item--i-150277
https://www.canleyclassics.com/trium...olumn-switches
Could be from Herald, Vitesse or Spitfire of the same era as your car.
That means the switches could also be from the same models. The housing they are fitted in could be Fiat, but inside might not. Are the switches labelled Lucas?
Like these?
https://rimmerbros.com/Item--i-GRID005829
On the Herald and Spitfire, the two stalks operated the indicators, usually on the right, and the headlamps on the left. The headlamps were three positions I think, marker lights, dipped and main beams. And might be a flasher is pulled.
I've forwarded a link to my brother, he still has a Herald and so may recognise it better. Will report back if helpful.
Likes Parabolica liked this post
13 years motor trade, 16 years motor industry. 14 years Driving Instructor & 7 years Fleet Trainer
Panda Alessi
portland_bill is offline Reply With Quote Quote
Old 08-01-2018   #3
Trader Rating: 1
My brother has had a look at the remains of his Herald. The horn button is certainly a Triumph part, most likely Herald, but the switch is definitely not.
So we're back to your original assumption that the switches came from a Fiat of that era.
Probably a good idea to repost the original question in both '124 Spider (classic)' and the 'Other Fiats' sections, as those are where potential owners are most likely to see them.
My guess would be 124 Spider, as a similar concept.
Panda Alessi
Old 09-01-2018   #4
USA
I wish it was Lucas. I am quite familiar with most things Lucas. This is definitly an Italian made part as evidenced by the markings noted on it as detailed in my inquiry.
Thanks much for your help.
Old 09-01-2018   #5
varesecrazy has donated!
Quote Originally Posted by troutmalt View Post
I suspect you need to SEARCH Fratelli:brothers...
Rather than Bratelli
Old 09-01-2018   #6
Quote Originally Posted by varesecrazy View Post
https://www.ebay.co.uk/itm/EARLY-CLA...EAAOSwl8NVeJUm
does it have an emblem like this..?? Vi and an "F"
an other quick SEARCH found this - may answer some questions..
( a "British car" with Italain switchgear.. as imported to the US..)
https://www.ebay.co.uk/itm/1112188-5...UAAOSwhglTwnmX
Cardiff / Oxford
Old 09-01-2018   #7
USA
Thanks for trying. No, that is not the part. Hopes dashed. ;-(
Old 09-01-2018   #8
USA
I Googled Fratelli and unfortunatly a lot of hits but would only work for me I wanted a pizza. :-)
Actually, I am a bit hungry now so good post. :-)
However, you gave me a great idea. I will do a Google search for Fiat parts in Rome or Italy.
Old 10-01-2018   #9
Not the same part.... just same company...
Does the branding..cast marking look similar
Old 10-01-2018   #10
USA
No luck there but I do appreciate your attempt to help me.
Old 10-01-2018   #11
USA
Bang, I think I have finally found the Fiat model my part came on. Appears to be a Fiat 500 part. But it is out of stock and if found by the vendor will be over $500.00. Way out of my budget.
http://www.fiatplus.com/3-POSITION-S.COLUMN-SWITCH.html
Does anyone have a domestic source or junk yard for used Fiat parts? Or an overseas source for this part, preferred used but can't be choosy.
Old 10-01-2018   #12
USA
Two questions on using this site please.
#1 How can I add to my thread without posting a reply?
#2 I can obviously post an image when starting a thread. But I can't figure out how to post an image in my reply. Only choice seems to be to post a URL or some Google thing I have no images in and can't figure out how to insert them.
Old 10-01-2018   #13
have a look in the classic 124 section for threads on US based specialists.
when you make a FULL reply..
there will be a "paperclip" icon at the top of the message box.... by Smiley face.. this is where you can link images,
Charlie
Cardiff / Oxford
Old 10-01-2018   #14
USA
Aha, the paper clip exists if you use the replay button on the bottom left fut not if you use the one on the bottom right.
Thread Tools
124 Italia Intermeccanica troutmalt Newbie Central 1 08-01-2018 11:40
Italia Intermeccanica troutmalt Newbie Central 0 07-01-2018 20:01
(T) Fiat 500 1969 model? Robbyrob1273 500 (Classic) 14 01-01-2017 18:25
(G) 1969 fiat spider 850 1969fiatspider850 124 Spider (Classic) 2 15-08-2015 17:42
Fiat 600d 1969 AMIN SKPJ Newbie Central 0 08-06-2011 18:10
