littlemouse
Hi all, can anyone tell me where the engine number can be found on the 1600tc, can't seem to see one anywhere
I had forgotten that the 131 is rear wheel drive thus the bell housing is not very accessible like on a transverse front wheel drive.
Mirror on a stick?
If the engine is the original for the car then from a chassis number it may be possible to find the engine number.
That is the Engine BASE type number.
eg. 138AR2
The full number
e.g. 138AR2.xxx.0nnnnnnn
is stamped on the end of the block and is not casting moulded on the front of the engine block.
Hope this qualifies base and full engine numbers.[/QUOTE
That's not correct, the engine number is indeed the one by the oil filter, I do know what an engine number looks like, it's stamped (not cast) onto the flat section just by the oil filter housing, it's not a casting number as you suggest, thanks for trying to help anyway
I have some epic memories of my strada 130 tc, guy Croft built on twin 45s with some 48 jets, cams sang to 9200rpm and 3rd and 4th gear pulled from 25mph to 120mphOK thanks for that info littlemouse.
Have just check our 2.0L TC in our 130TC. Same as your 1.6TC.
I'm obviously too used to 80s Fiat single cam block where they put the number on the end of the block.
Don't often get things incorrect. My apologies for the Goose chase.
