Hi all this is my post, sorry in advance for how long it is.
I have a problem with my 64 plate Fiat brought in February from Fords at Windsford. It stutters/judders a lot when changing gear as though it's not getting the full power then after a few seconds it's fine and pulls away. Sometimes it does this then the engine management light comes on and it goes into limp/crawler mode where it's got hardly any power. The car then vibrates/judders when standing still and the exhaust sounds like a tractor!
I've had this problem since March when the spark plugs went. Spark plugs replaced but problem continued. It was very intermittent problem so thought all was ok but then it's got worse and worse. Was serviced 28/11/16 and they found nothing wrong, took it in to be looked at on the 29/12/16 they said they found a few error message son the ECU cleared those off but didn't even get 15 miles in it before it happened again. Called Fiat up to book it in again and they are now saying diagnostics not covered under 3rd year warranty, although when I asked last week it was. Does anyone one know what it sounds like it could be? Also what is covered under 3rd year warranty? Fiat seem to do/say anything to get out off it. The problems getting worse and worse where it's happening nearly every time I drive it and if I can't get it sorted I will have to go down the legal route of it not being fit for purpose.
