im Axle Specialists
Old 10-10-2005   #1
Fat pigeon... APPLE!
JonnyBoy's Avatar
Trader Rating: 1
JonnyBoy has donated!
How do you increase the fuel pressure on the 1108cc FIRE engine?
Thought I'd post this here as it may be relevant to Cinqs/Seis etc as well as Puntos...
The article on FIRE engine tuning in Retro Cars recommends "winding up the fuel pressure a bit" to increase power... unfortunately it doesn't mention how you would achieve that! Is there a regulator that I can adjust, or would I need to fit an uprated regulator or fuel pump?
Past: '91 Uno 45 Formula; '94 Punto 55SX; '58 Bravo 1.9 Multijet (150BHP) Dynamic, with extra toys
Present: Several, but nowt Italian...
JonnyBoy is offline Reply With Quote Quote
Old 10-10-2005   #2
Trader Rating: 1
Luke has donated!
George Wants Beer Champion, Home Run Champion
Re: How do you increase the fuel pressure on the 1108cc FIRE engine?
Quote Originally Posted by JonnyBoy
Yea i think its a case of a new pump and regulator The spi systems only use a low pressure system. There may be some leway in the current pressure regulator though, im not too sure not having seen the system
Luke is offline Reply With Quote Quote
Old 10-10-2005   #3
Funny saying here
jamie86's Avatar
Trader Rating: 1
jamie86 has donated!
Quote Originally Posted by luke1985
Pete did say something a while ago but can rem what tbh
Quote Originally Posted by A wise person
Mini invented the giant killer, VW started the genre, Ford & Vauxhall Desecrated it, but the Peugeot 205 GTi was undoubtedly the king of the breed.
jamie86 is offline Reply With Quote Quote
Old 10-10-2005   #4
Banned
Oldschool has donated!
You can drop a Punto 75 pump in the tank. But you might encounter some problems with the fuel line connectors if you use the Cinquecento sender unit to house the pump.
Alternatively you could use an external pump.
With the existing pump you would not be able to increase the power worth mentioning. If you can double the fuel pressure you will get not more than 40% more fuel in. Winding up the fuel pressure on the existing system is rather a myth.
Oldschool is offline Reply With Quote Quote
Old 10-10-2005   #5
Trader Rating: 1
What edition of retro cars featured the FIRE engine, i missed this one ????
SuperUno is offline Reply With Quote Quote
Old 10-10-2005   #6
Funny saying here
jamie86's Avatar
Trader Rating: 1
Quote Originally Posted by SuperUno
https://www.fiatforum.com/showthread...ght=retro+cars
Old 10-10-2005   #7
Trader Rating: 1
Since that thread is blocked, can i say thanks to the person who sacnned in the Retro cars piece on FIRE engines.
Now to test the works printer
Old 10-10-2005   #8
HP
I was only doing 80...
HP's Avatar
HP has donated!
You could wind down the allen screw on the fuel pressure regulator inside the throttle body, but to do so without a pressure gauge and exact knowledge of what you want and need to do would be a bit pointless. To some extent the lambda sensor will just tell your ecu it's running rich and reduce the injector duration, negating any effects.
You're not going to gain much bhp by just making it run a bit richer, anyway.
Pete.
"Make something idiot proof and someone will just go and build a better idiot".
HP is offline Reply With Quote Quote
Old 10-10-2005   #9
jenks69 has donated!
I was thinking along those lines, but wasn't sure. These Fiat engines seem too clever to be simply and cheaply conned into performing better
jenks69 is offline Reply With Quote Quote
All FIRE engine cam specs needed smokeme Lets Talk FIAT 12 22-11-2012 17:52
(G) Problem! Fuel tank pressure Hagalaz Uno 8 24-10-2011 12:24
(T) fuel pressure blitzen Cinquecento / Seicento 1 12-07-2003 04:14
(T) Low Oil Pressure - Stop Engine thetman Stilo 6 12-07-2003 00:30
