:wave:
I discovered yesterday a "unique" probem that one can encounter with a semiautomatic gearbox; or at least the Fiat semiautomatic gearbox using a "manual" style dry clutchplate.
They can when on the limit get "bogged down"; :bang:leaving you with a slipping clutch and impossible to get wheelspin or enough power to the wheels to pull you through and out. You quite literally in my case have a "beached" car.
Background:-
I do a lot of running and sea swimming (triathlon training); and most days this means I have to drive along a beach. I mean drive actually on a proper beach (no road).
The beach is a combination of sand; gravel, shingle; and it varies considerably in softness and slope. The winter storms here changed the whole dynamics of it.
Yesterday I discovered a unique problem with the semi auto gearbox that you can encounter..
The car in question was a 2007 Fiat Panda Elengaza 1242cc semi automatic gearbox.
15,500 miles and in perfect working order.
Gearbox is working perfectly. Good job Fiat.....only issues with it has been sometimes when it gets "confused" when pulling off. If you accelerate; and then have to suddenly back off it can stall. This has happensabout six times a year. That is not a gearbox fault on ours, I believe; it is just how they are. Just sloppy design for that situation.
For many years I have been driving along this beach. All my historic Citroens (soft suspension/big tyres) have never got stuck.
My Fiat Uno (manual) was touch and go with its smaller wheels. But when it did bog down on this terrain the *only* way to "continue" was to let the wheels spin and as it dug down it just found traction on the subsurface layer and "jumped/hopped" forward. No amount of clutch slip would allow it to drive through. On this terrain with this car you had to let it wheel spin and hop to get any headway.
A normal automatic is often much easier to drive offroad (at least uphill or on the "flat" as the "fluid" coupling allows less wheelspin pulling off. -Downhill can be a different matter though with runaway/lack of engine braking)
Yesterday it was sunny.
I arrived on the beach as normal to find a variety of 4x4's parked. Beach party.The only way along the beach was on the softest ridgiest bit, between the parked 4x4's; people; dogs; kids; berms and the waves themselves.
Generally I think Fiat have seemed to have done a good job on the gearbox. But I had the usual wheelspin/hopping; and of course trying to balance it without a clutch is a little different to a manual. In some ways easier and some harder. But usually you can drive them in the same way as a manual car off road.
However I was eventually left with semi buried wheels (maybe up to hub deep at the greatest depth).....eventually with *full* power and accelerator fully down with *NO* wheelspin. Stuck :bang:
A bogged down; beached panda.
The car was just holding the engine revs there (slipping) on the clutch- engine revving away. Not enough drive to the wheels to pull me through, or curiously wheelspin. Of course (clutch) smoke started to come---very quickly actually.
Ideally Fiat need to "rejig" the sensors to *allow* wheelspin under extreme full throttle. It did not matter how I applied the power. Snapping it on or building it up. Same result;not enough drive to the wheels to move or to wheelspin.
I cant remember at this precise point whether I was trying to go forwards or backwards to navigate my way around the berms/cars. I had to shuffle. But fortunately (and only just) by going into a forward gear/or reverse.....did I just manage to break the "hold" on the cars wheels by the beach material; and promote a wheelspin to claw out.
I admit this was extreme terrain; and of all the off roading I have done in my life (quite a lot); it was some of the most demanding in terms of purchase and drag on the car.
Incidentally all the other cars on the beach were four wheel drives. Two Mercedes (2WD's) did try and venture onto the easy part of the beach. They got stuck. Totally. They had to get towed out by a landrover.
I watched this unfold swimming from the water.
It is only really BMW's and Mercedes that I have seen getting totally stuck on the beach...rear wheel drives as always.
Two main points came out of this.
Under more harsh (but not that extreme) offroad conditions you may have to drive the semiautomatic Fiats differently to either a manual or an automatic car "offroading"--when they are on the limit.
Secondly I was suprised on the Fiat at how quickly the clutch started to smoke. I have driven many other Citroens, some Ford's and Alfasauds with full power and fully loaded clutch slip before; either off road or towing boats up steep boat ramps; and have never had clutch smoke in such a short period of time.
It makes me wonder whether Fiats have weaker clutches than historic Citroens and other cars?
The beach is just within traction limits. There is no point in my trying to alter or adapt the car for this beach. However if I was doing more or a transcontinental trip again in a semiautomatic; then I would look into how to overide the sensors; to "allow" me to wheelspin under more extreme conditions.
So if Fiat read this......you need to alter the parameters/tuning of your microchips or sensors. They fall short in this area.
If only I could also fit a manual clutch pedal also onto the semi-auto box. Best of both worlds:slayer:
All in all a good gearbox. But they need to be remapped in at least two areas.; for off road driving extremes; and the stall thing at junctions.
Ironically the problems are the opposite of each other. on one the clutch slips; and on the other it does not (hence the stall)!
Come on Fiat--I know you can solve this and do better!
Background:-
