hi. I am a new member and this is my first post. I am desperately looking for help as I am not very savvy with cars.
right first things first, I drove my seicento a couple of days ago with no problems, I tried to get back in the car half hour later when it wouldn't turn over and the key CODE symbol was appearing but slickering slightly. a box on the right hand side under the bonnet was rattling. to cut a long story short I had someone looking at it and he checked the battery and it was low, we charged the battery for a while and then the car started with no warning lights. we disconnected all cables from charging it and turned the engine off. the car started again a few times with no problems or warning lights. I left the battery charging for an hour or so then started the car fine and drove a 20 minute journey home. I figured it was the low battery that was causing the immobiliser to kick in. the next morning I had the same problem, CODEkey symbol appearing, car wasn't attempting to turn over. I got it to the garage where we found a snapped earth cable. reconnected this, the car was turning over but not firing, we tried a new crank sensor but no joy. now the CODE symbol stays on at all times while the ignition is on. I don't have the master key to override the system nor do I have the 5digit code to insert.
sorry for the long essay but I felt I had to give u all info I had, and hope for some good advice?
thankyou in advance
thankyou in advance
